Re: 656 remote unlatching pressure
Posted by K.B.-826 on November 01, 2005 at 20:02:09 from (66.188.223.190):
In Reply to: 656 remote unlatching pressure posted by FormerlyPaMike on November 01, 2005 at 14:18:37:
Mike, this is much easier to do with a Flow-Rater, since those have a valve you can turn in to gradually increase the pressure until your lever unlatches. You'll have a hard time doing this with a guage plugged into a coupler, since it will probably register max pressure the second you latch the lever back. I'm sure you don't want blow $2000 on a Flow-Rater just to make this one little adjustment, so do like Allan suggests. That's how I do it at home. The important thing is that the lever unlatches before max pressure is reached, but does not unlatch before the cylinder on the implement you are using reaches the end of it's travel in the direction where it works the hardest, such as raising a loader with a fully loaded bucket.
Post a Followup
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
