Re: warning lite?
Posted by John T on November 02, 2005 at 20:15:17 from (66.244.90.98):
In Reply to: warning lite? posted by tn terry t on November 02, 2005 at 18:08:29:
Terry, some people use what I refer to as an "idiot light" as opposed to an ammeter to tell when the alternator is working. When people convert to a GM 10 SI 3 wire alternator they need a voltage source to excite the lil No. 1 side terminal, and many simply add the idiot light in series with a wire from the ignition switch (or coil) to the alternators lil No. 1 side terminal. HOWEVER if the light they use is a lot less then 10 ohms (although it may still work excet for the run on problem) it doesnt provide the needed current limiting protection for the alternators internal diodes. THEREFORE I recommend a 10 ohm resistor (see below). A voltage source is required on the No. 1 terminal to excite the field for the alternator to kick in and start to charge, which is why one sees a voltage feed there regardless if direct off the coil or through an idiot light or a resistor and diode etc. Your same type of question came up earlier today on another board so I will copy n paste my same answer below. The diodes I use are 5 amp with a minimum of 50 PIV. Thats actually rated higher then required but it has bigger leads easier to wire in. Heres my other answer which applies to you: Jubal, In addition to Olds good advice, heres my take on your question: If it runs on, the very FIRST THING I RECOMMEND (if youre not using an idiot light in the circuit) is to install a safety 10 ohm resistor in the excitation circuit to the Alternators lil No. 1 side Excitation terminal. That serves as current limiting protection to protect the alternators internal diodes. In the event youre using an idiot light in that circuit, it can serve as the desired current limiting protection, but if its resistance just happens to be a lot less then 10 ohms, I would still add some resistance so theres a total of at least 10 ohms (idiot light plus resistance) in the excitation circuit. Nowwwwwwwwww its often the case once you add the desired 10 ohm resistor or an idiot light the run on stops. HOWEVER if she still runs on, then add a diode as Old recommended. Its acts as a one way current flow check valve so the alternator dont backfeed the ignition n she shuts off properly. IT MUST BE WIRED IN CORRECT POLARITY + Anode end to coil/switch, - Cathode end to Alternator or it wont work. The above is for the GM 10SI 3 wire Negative Ground alternators. Sure, Ive seen plenty with no currrent limiting protective resistance n they worked fine,,,,,,,,Ive seen some that run on while others dont,,,,,,,,,,but Ive seen some fried internal electronics on the Alternators which may well have beec caused by overcurrent or spikes or surges etc. Good Luck n God Bless John T Nordhoff in Indiana, retired electrical engineer
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
