Re: Water good , in oil -bad ! ( long )
Posted by farmallhal on November 05, 2005 at 06:08:48 from (64.24.35.17):
In Reply to: Re: Water good , in oil -bad ! ( long ) posted by Randy-IA on November 04, 2005 at 20:15:17:
Randy, you are sure going to like your owners manual when it arrives. The M hydraulic pump holds 6 quarts. You can make a dipstick from a piece of .125" dia. straight wire by welding a washer on the top so it can't fall down the filler neck. Mark it at the 5 quart and 6 quart levels as you fill it and you have a dipstick. I use 30 wt. non-detergent motor oil (detergent will foam and cause problems). A lot of folks here on the forum will suggest Hy-Tran which is thinner and more prone to leaking. Depending on what you are going to use yur hydraulics for and if you are in cold climate that will also help you decide. You might want to use whatever you use with any other tractors so the fluid is common to everything. I've heard even the green tractor stuff is fine. I don't think those old hydraulic systems were fluid sensitive. If you have a pipe cap on your belly pump filler neck it should have a small hole for venting. On your belt drive system it is lubricated with the fluid from the differential/transmission. If you take it apart for any reason you will need to add fluid (same as in tranny) so you have instant lubrication instead of the splash system supplying the lubricant. Just fill it through the plug on the top of the gearbox and it will hold somewhere between a pint and a quart. This is well covered in the owners manual. Have fun and enjoy that new M. Hal
Home
| Forums
Today's Featured Article -
Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
