Re: Oops. Now I did it. M question
Posted by Haas on November 07, 2005 at 19:24:15 from (12.65.72.5):
In Reply to: Oops. Now I did it. M question posted by e-manhunt on November 07, 2005 at 18:09:55:
As Jani said, you have likely tried to remove the hydraulic (Lift All) unit to get at the lost bolt. That unit is very heavy and the drive connection to the transmission as well as the pipe connections and the control connection on the side has to be removed to get it out. It is held in by four 3/8 inch bolts. If you decide to remove it, make sure you have help and do not drop it on any of your body parts, as it weighs more than 100 lbs. I also, do not agree that the bolt will do no harm. I don't think there is room between the ring gear and the housing to clear a bolt of the size (1/2 inch??) that holds on the starter. It's gonna get wedged between and something will be damaged. I think the magnet suggestion is a good start. Beyond that, I don't see much option except to drop the lift all unit. I'll take a look at mine tomorrow and see if there is an inspection hole I've forgotten about.
Post a Followup
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
