Re: RE: 434 IH Starting
Posted by Janicholson on November 09, 2005 at 06:39:21 from (199.17.6.175):
In Reply to: Re: RE: 434 IH Starting posted by JB2 on November 08, 2005 at 17:09:48:
My two cents. In my experience, there are four terminals on this solenoid. they are: 1}Main battery connection (big nutted terminal). This has two wires on it. One heavy cable from the battery non-ground terminal, and at least one other(usually 10 ga.) going to the Amp meter. (others may be added to this but are not usually correct because they avoid the Amp meter). 2} The "S" terminal (small threaded stud with or without nut). This is the terminal that causes the solenoid to operate. It is not "hot" it is from the start terminal on the key, or start push button. This needs voltage to engage the starter. The solenoid windings are connected to this terminal on the supply end, and to ground through the solenoid mount on the other end. 3} "I" terminal looks like the "S" terminal (small stud, nut or not). This is a ballast resistor bypass terminal. It is connected to the coil side of the ballast resistor in the ignition circuit. It is connected, on the inside of the solenoid, to the terminal going to the starter. When starting, the battery voltage drops to around 10 volts in cold conditions. To minimize the effects of this reduced voltage this circuit supplies voltage directly to the coil. Helping cold starting in many cases. (this is often ignored and should not be). 4} the Starter terminal (big and with a nut) this goes directly to the starter and causes all actions including engaging the pinion to ring gear. The starter has no other input. This may clarify the operation of the 4 post solenoid. JimN
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
