Re: New Holland 328 Spreader
Posted by Michael Soldan on November 27, 2005 at 06:03:20 from (24.235.41.226):
In Reply to: New Holland 328 Spreader posted by Tedd on November 27, 2005 at 05:52:08:
Tedd, your apron chain will be very standard and by removing a link and taking it to just about any machinery dealer , you will be able to buy enough links to make your repair. I have found the easiest way is to attach my come along to the center of the bar on the apron and to the next center of the bar between the break, then pull them tight, close together, then I have enough sideplay to turn the chain and drive in the new link. Aprons are fairly simple, just make sure you have an equal number of links between each conveyor bar. When you are done the repair you should tighten the apron so it is not loose down to the ground, there are adjustment tighteners at the front bottom corners, again each side should be the same adjusted lenght. I have a New Holland model 327 which is almost identical to yours..good luck with the repair..incidentally I can buy a complete new apron chain for around $500 and separate links should be around $2 each, usually 2 links will make a repair, sometimes when the chain is worn and stretched a bit you need to remove a link on each side to get the apron tight enough, then you have two "spares"....Mike in Exeter Ontario
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
