Re: 8volt instead of 12v.......
Posted by John T on November 27, 2005 at 14:20:29 from (66.244.90.98):
In Reply to: 8volt instead of 12v....... posted by Dellbertt on November 27, 2005 at 11:00:57:
DELLBert, Its possible to tweak up a 6 volt Voltage Regulator some to better charge an 8 volt battery, but Ive NEVER been a fan of 8 volts. For one, its an oddball battery n arrangement,,,,,if its a coil ignition and you dont add some ballast, the coil runs a tad warmer and the points can burn a bit sooner,,,,,,,,,likewise, the bulbs will burn brighter but burn up sooner. If a body is dead set on converting, I would go ahead n convert it to the way more standard 12 volts n be done with it. The original 6 will start better IFFFFFFF one uses the biggest heaviest and highest rated battery that will physically fit in the box and use 00 Gauge cables. Ol Frank (F I T) put one of those 6 volt AGM Optima batterys in his Case n I think its rated something like 1000 CCA but costs more, of course.
John T
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
