Re: International A110 Pickup truck
Posted by T_Bone on November 27, 2005 at 17:49:16 from (4.240.90.240):
In Reply to: International A110 Pickup truck posted by Nebraska Cowman on November 27, 2005 at 06:45:31:
Hi NC, I can't help with the A110 but depending on which PSD you want to use. Mine is a 02 F350 PSD with a ZF6spd, 3.73, DRW, 4wd, and with 26kGCW at 1800rpm I had no problem maintaining 60mph on flat roads in 6th(OD) and 5th gear on the small hills. The 02 PSD makes 520ft/lbs at 1600rpm and 275hp@2800rpm. Other years, 99'+, are slightly less with the 03 7.3 slightly more. I added a 2nd tractor for 31kGCW and that was too much for this truck. I now had to use 2250rpm to 2500rpm (turbo rpm) to maintain 60mph. I was also fighting a 30mph headwind. I normally pull my RV, 16kGCW, at 1600rpm on the flats and 1800rpm on the 8% grades. At 1800rpm the turbo adds just a tad of boost and makes a huge difference in climbing the grades. I drive for maximum fuel ecomony at all times so most of my travels is at 1600rpm as this yeields the best fuel mileage. The Ford ZF6spd is a piece of junk and shifts like one. Also the stock Ford or LUK clucth is too weak for the PSD. Both Rockwell and Southbend build a clutch rated at 11ooft/lbs or enough to last in a PSD. Personally I would look at a older mechanical injected diesel with a turbo as then you can run B100 or home made fuel where the PSD will have a few problems with back yard fuel. I would also look at a Eaton 18spd auto-shift tranny as then you can have a double OD for great fuel ecomony plus have a 17% ratio spread. The autoshift needs a clutch to stop and start but up/down shifts like a fluid automatic but with gears and no clutch to shift. It shifts by rpm that you program in and can change at will. I have a neighbor that uses a 6cyl Ford tractor engine in his pick-up. He stated the engine has worn out two pick-ups and now working on it's 3rd truck. He keeps the engine & tranny and fuel componets and changes the rest of the truck. T_Bone
Home
| Forums
Today's Featured Article -
Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
