Re: I 340 water in oil
Posted by Nat on December 01, 2005 at 06:49:58 from (12.45.226.66):
In Reply to: I 340 water in oil posted by Doug in Wi on December 01, 2005 at 05:39:39:
Unless you only change your oil about once every decade, there's something more sinister than condensation causing that much water to end up in the oil.
I don't know if you can assume that the water isn't coolant, because I'm not sure if the other components of antifreeze don't mix with oil.
What are the conditions under which you operate the tractor? What are the conditions under which you store the tractor? Is the muffler covered if the tractor is stored outside? Do you run the tractor through water?
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
