There's quite a bit more raised on those plates than readily appears to the eye -- all the lettering except the numbers that are obviously stamped in.
I had good luck with the only one I've tried. I stripped the whole thing, masked off the open spots where the model, ser # and rpms are stamped, as well as around it (so as not to have to remove it from the tractor, or seat support in my case). Then I shot the whole thing with a few thin coats of black lacquer from a rattle can. Followed that with a light wet sanding with 2000 grit to expose the raised lettering. Took a couple of tries to get it right to where I then threw a coat of clear lacquer over it and removed the masking. Turned out pretty nice.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
