Posted by John T on April 08, 2009 at 11:49:44 from (66.244.97.31):
In Reply to: Re: Farmall 460 coil posted by Janicholson on April 08, 2009 at 10:29:04:
Yo Jim, Im not aware of any Thermistor (a resistor that increases in ohms over time as it heats up) use in our old tractors, but believe Ford or someone used it in some automotive applications?????????? It would save a lot of the start by pass and normal ballast problems fer sure.
While on the subject, many here refer to 12 volt coils as being "internally ballasted" sort of like in part of the can theres this stand alone discrete actual RESISTOR. Although a few such did exist, some of which had a lil ring around the can separating the resistor portion, and jdemaris or SoundGuy or someone once even posted pics of old coils with actual internal resistors (some of which were used in circa thirties cars I believe), MANY OF THE TYPICAL GARDEN VARIETY 12 VOLT COILS ACTUALLY HAVE NO INTERNAL BALLAST RESISTORS, but their increased resistance is simply due to more coil wire length or higher resistance wire ANYONE WANNA TAKE ISSUE WITH THAT feel free, its the best info I have available.
Maybe you or Bob M or jd or someone has details or specs or data on the subject?? But far as I know most typical 40's n 50's tractor 12 volt tractor coils DO NOT have an internal pure stand alone discrete resistor hid somewhere inside there
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
