Re: Smokin' H_I agree
Posted by Janicholson on December 18, 2005 at 06:47:31 from (66.173.50.118):
In Reply to: Smokin' H posted by Eric Allen on December 17, 2005 at 23:46:40:
The only thing to add is an additional test for valve guide wear. (and a cheap fix) If the engine smokes most after idling for a while, or after going down a hill in 5th with the throttle closed, then cleans up pretty much when being worked some, then guides may be the issue. High vacuum causes more oil to be drawn in past the loose guides. If this is the case, putting on Perfect circle valve seals (or even just umbrella seals) does not require removing the head. Tips Remove rocker shaft, leave pushrods in. Work on one cyl at a time. Put piston on TDC and lock engine in that position by putting in 5th and locking brakes. (keeps valves from falling into the cylinder if pressure is lost) Use a 3/4" deep socket and plastic hammer to rap the keeper downward on each valve to break them loose. Put shop air pressure in the cylinder through an old spark plug brazed to an air fitting. (keeps valves closed with retainers off) Use a tierod "pickle fork" and a piece of 5/16 chain to make a spring compressor to remove the keepers. Bolt the chain to holes used for rocker shaft. Don't use the rocker shaft bolts. Install the seals, and reassemble. The process takes as much time to organize as it does to do. JimN
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
