Re: Leaking Super M
Posted by Bob M on December 19, 2005 at 06:10:40 from (151.190.254.108):
In Reply to: Leaking Super M posted by Retcol on December 19, 2005 at 05:28:16:
Leak could be from any of (3) possible sources. So you need to figure out exactly WHAT is leaking. Possible sources: 1 – Rear main seal in the engine - will leak crankcase oil. 2 – If the tractor has belly pump hydraulics, the hydraulic pump input shaft seal could be leaking. The leak will be hydraulic fluid (is thinner than crankcase oil and more or less clear in color.) Note: If your Super M has live hydraulics (the hyd pump is on the right front side of the engine) it cannot leak hydraulic fluid from beneath the tractor! 3 – Transmission front seals (input shaft and/or hydraulic pump drive shaft seals). These will leak heavy transmission lubricant. Also you can remove the dust cover from the underside ahead of the transmission, shine a light up there and probably see the source of the leak. ----- FWIW #1 is most difficult to correct – requires splitting the tractor. #2 and #3 however are relatively straightforward. These require only minor disassembly (removal of the hydraulic pump, tranny input shaft, etc) to get at. My experience is #3 - transmission shaft seals - is the most common source of leaks – and fortunately also the easiest (and cheapest) to correct.
Home
| Forums
Today's Featured Article -
A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
