986 running problem
Posted by Eldo case on December 27, 2005 at 04:54:14 from (72.161.244.57):
986 will start cold then run a little bit then die and won't start until it has a little starting fluid. The owner said it seemed better with the block heater warm. It will run ok unless you lug it and it dies or you idle it down fast it will die. Then it won't start unless you use starting fluid or it sets for ten minutes or so. Is it the pump? Thanks!
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
