Re: changing hydraulic pump rotation
Posted by farmalldan on January 19, 2006 at 06:56:26 from (64.154.26.250):
In Reply to: changing hydraulic pump rotation posted by Yellott Canby on January 18, 2006 at 20:06:24:
Yellott, Some hydrauic pumps are designed to run in either direction. However, it may be difficult to confirm this at this stage of the game. Many gear and vane pumps are reversible by reversing the "cartridge". The cartridge is the center section of the pump which contains pumping element and sometimes ports. The cartridge is reversed end for end. However, you will have to check for proper seal drain function or you will constantly blow shaft seals or maybe the case. If external seal drains are not present, then the seal cavity is internally drained back into the pump suction (most common). Bidirectional pumps are usually drained into both ports via check valves so that the suction automatically accepts any leakage into the seal cavity. On rare occasions, different end plates are required when reversing rotation to accomodate the seal drain function. Piston pumps don't usually (be careful here. There are many exceptions in the heavy duty market) care which direction they rotate if the seal drain issue is addressed. Best to identify your pump and consult with the manufacturer to determine if and how it can be reversed. Otherwise, you risk blown shaft seals or possibly a ruptured pump case. Good luck.
Home
| Forums
Today's Featured Article -
Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
