Re: O/T Chevy intake leak !!!!
Posted by Ron in Nebr on February 02, 2006 at 18:36:08 from (12.192.38.156):
In Reply to: O/T Chevy intake leak !!!! posted by Paul Shuler on February 02, 2006 at 13:48:17:
Allan and the others are right- if it's leaking antifreeze it's the gasket between the intake and the head. Your description of "behind the distributor" was probably what got you the advice to just use RTV, since those valley gaskets often can be and are replaced with RTV. But, NEVER use just RTV between the manifold and the head, especially around the intake ports. Gasoline turns RTV to a gell. I always just put a smear of RTV around the waterjacket openings with my fingertip and use nothing around the ports on the gasket. Getting back to your problem, sounds to me like one of two things- either mismatched due to faulty machine work(in which case it "should" leak at other spots too). Lay a straightedge along the machined area of both the head and manifold and check for a low spot...Either that, or else you could possibly have a bad intake manifold casting- either poorly machined from Edelbrock(the straightedge would show that) or even a pourus casting that lets antifreeze "seep" through the aluminum. Another thing, not sure if the Air Gap manifold has it, but some race aluminum intakes have a water outlet port at the rear flange surface to allow external water plumbing. If yours has this(I doubt it) the plug there could be leaking. If it was me and there was nothing visibly wrong, I'd swap on another intake(you probably have the stock one lying around) and see if that cures the problem. One final thought...since these are "redone heads", Check and see if one of the rear intake bolts isn't drilled clear through into the waterjacket...I doubt this is the case too, but ya never know...a dab of sealer on the bolt threads would cure that.
Home
| Forums
Today's Featured Article -
Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
