Re: 6 or 12 volt?
Posted by John T on February 05, 2006 at 14:44:28 from (66.244.90.98):
In Reply to: 6 or 12 volt? posted by Mark Co on February 05, 2006 at 13:14:34:
Mark, Im not a fan of the 8 volt system, its an oddball to say the least. If you decide to change, I would go ahead and convert it to a full much more standard 12 volt while youre at it. If it has a genny with a Voltage Regulator, you can simply change to a 12 volt Voltage Regulator to charge a 12 volt battery, thats NOT perfect or the engineering proper way to do it, but it can work even if marginally. The starter will still work at 12 volts, although it can be a lil tough on starter drives. A better way on the genny is to have a genny shop convert the old 6 volt unit to a full fledged 12 volt genny or just buy another 12 volt unit and a 12 volt VR. Of course, you could also change over to a Negative grounded 12 volt alternator system like many do, its your call. If its a coil ignition instead of a Magneto (NO change needed), it would be cheapest n easy to add an external series voltage dropping (12 to 6) Ballast Resistor after the switch and ahead of the coil, unless you have a full 12 volt rated coil you wanna use. Change any light bulbs to 12 volts, of course. If you decide NOT to change, to improve cranking performance, I recommend the biggest highest rated battery that can physically fit into the box and the use of 00 Gauge battery n starter n ground cables with a ground cable as close to or on the starter as possible and be sure the starter switch and starter are both in top condition. If the engines not worn out and shes tuned up real good, even 6 volts ought to still start an M in cold weather with the proper oil and good fuel by milking the starter up n over one piston at a time. However, if anything at all is marginal, thats where the 12 volt can still start her where the 6 volt may fail. The good Bob M has all sorts of wiring diagrams to get you converted also. Best wishes John T
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
