Re: Smoking H.
Posted by captaink on February 08, 2006 at 07:28:32 from (66.115.214.56):
In Reply to: Smoking H. posted by Bernsy MN on February 07, 2006 at 14:33:47:
There isn’t enough information to tell until you get it apart. What I can tell you is that you probably won’t have major crankshaft work and that you camshaft bearings aren’t worn out terribly.
Pull it down and start measuring and checking. It could be stuck or worn rings, worn sleeves, worn valve guides or a combination of the above.
You can do everything without taking the engine out or splitting the tractor. I do suggest however that if you do more than just rings that you pull the motor and get the block cooked out at a machine shop. These old girls have been around a long time and have been overhauled just as you propose to do many times. Your engine could possibly have collected a lot of crap in the water passages which inhibits coolant flow to the head. They are also noted for cracking heads which I and my machinist have theorized is related to the above crap in the block. The down side to this is that it will cost you more $ for cam bearings and the cleaning. Just something to think about.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
