Farmall 400 Power Steering Installation Questions
Posted by Troy in MI on February 11, 2006 at 16:41:54 from (216.65.162.28):
I wrote a few weeks ago to ask some questions about installing a factory power steering setup (Behlen unit going into the hydraulic blocks). I have the correct blocks but have since learned on this site that you need to block off one of the three orifices on the inner hydraulic control block. My question is, which hole needs to be blocked? I find one hole that is smaller than the other two. There’s one that’s about ½” diameter that’s about the same height as the smaller hole. And there’s another that’s about ½” diameter that is below the other two holes. I believe that it’s the lower ½” hole but want to be sure before I start cutting threads. Also, my plan is to use a ¼” pipe plug and to cut threads into the inner block. The plug would go on the LH side of the block (toward the reservoir tower). I would then use lock-tite to keep the plug from threading out. I thought I’d do this tomorrow but I just wanted to check with you guys to make sure I’m doing the right thing. Thanks in advance for any help.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
