Re: reverse gear gone?..Grinding noise..
Posted by Nat 2 on February 13, 2006 at 12:28:23 from (12.166.135.147):
In Reply to: reverse gear gone?..Grinding noise.. posted by Glendon Wentzell on February 13, 2006 at 11:13:28:
There"s no way to know what"s wrong without tearing into the tractor. It could be simple, or it could be an entire transmission rebuild.
Oil bubbling up around the dipstick... Well, the crankshaft spinning around will splash engine oil all over the place as a matter of course. If it"s not sealed up, the oil"s gonna come out.
IH tractors of that era had rubber plugs as part of the dipstick unit. You would twist to loosen, pull the dipstick, then tighten it back down after replacing the dipstick to seal the filler tube. You"re either not doing that, or the rubber stopper is messed up.
If it"s leaking around where the filler tube is pressed into the block, you need a new filler tube.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
