Re: Farmall Super A 3 pt hitch?
Posted by Hugh MacKay on February 15, 2006 at 19:01:17 from (209.226.106.180):
In Reply to: Re: Farmall Super A 3 pt hitch? posted by Robert Lorencz on February 15, 2006 at 17:52:30:
Robert: The first year I grew corn it was only about 10A I picked up a used two row 3 point planter. I had a pair of lower links Cat I, so decided to fabricate a hitch for Farmall 130. It was already equiped with 1 point fast hitch. Initially I got 2 pieces of 1-1/4" round bar to put through hole for rear cultivator mount. I welded a pin for lower link plus a head on the round shaft. That mounted it very much like yours. Problem was top link controls depth of planter, thus that back presure on top caused the lower links to flop tight one side or the other and ocasionally change from side to side. Of course with the lower links attached directly at final drives this caused them to be close to parallel. 30" rows were not very constant. I took a look at factry 3 points saw the principles of how they worked. I then got a section 3/8" wall 3"x3" square tubing, long enough to reach between final drives. I welded a plug in each end with 1-1/4" hole, and pinned it in there using the pins I had already made, devised a system so square tube couldn't turn over. Then I welded lugs about 20" apart on the square tubing for mounting the lower links. Then when I wanted to remove this and change back to my 1 point all I had to do was pull those 1-1/4" pins and unhook vertical linkage at the rockshaft. This made ground working tools center behind tractor. I see you have a stabilizer on your hitch and that will work fine for above ground equipment. but stabilizers must be removed for in ground equipment or you cant steer. This made my planter trail true and centered with tractor. If one started down a row, planter would center within 10'. You could easily do similar with what you have, I wouldn't bother unless you are pulling in ground working equipment.
Home
| Forums
Today's Featured Article -
Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
