Re: Case/IH CX 90- troubles
Posted by BC Glenn on February 23, 2006 at 07:58:08 from (207.69.139.134):
In Reply to: Re: Case/IH C 90 posted by Big Don on April 27, 2005 at 10:10:17:
Some posts awhile back showed some of you are familar with these tractors, so I was hoping you could give me some insights. Bought a Case-IH CX 90 with low hours a few months ago and has been great. But recently the shuttle shift (forward - reverse) on the steering column seems to have locked-up. The transmission (range and main) and clutch all seem to be working normally. When I try and move the shuttle lever out of the middle neutral area - either forward or back the tractor starts to go that direction and then any additional pressure results in gears starting to grind (even with the clutch pushed in). I can start the tractor with the shuttle in forward or reverse, but the high-low range lever must be in neutral and then it starts to grind with an attempt to put it into gear. Any suggestions - I'm not in the position to readily load this thing up and haul to a dealer. Thank you very much for any suggestions or recommendations. Any affordable repair manuals out there for this tractor (dealer $475 repair/$116 parts)?
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
