Re: super a pto ?
Posted by Haas on March 09, 2006 at 18:38:17 from (12.65.66.248):
In Reply to: super a pto ? posted by banjo on March 09, 2006 at 11:02:11:
I can answer part of your questions. If you don't have the belt pulley, you don't really need the O ring. The gasket under the cover should be sufficient. If you have a belt pulley setup, then the O ring is needed, because that is the seal to keep oil from leaking out. You don't use a gasket with the belt pulley assembly, instead there are shims to adjust the gear lash. You can get the O ring and the gasket for the cover from an IH dealer. I've had these off before, but I don't recall how the gasket and the oil holes work out.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
