Re: WD9 won't run on diesel
Posted by Ron in Nebr on March 28, 2006 at 14:43:47 from (12.192.38.133):
In Reply to: WD9 won't run on diesel posted by OK PSU Kid on March 28, 2006 at 13:18:28:
Those decompression linkages are notoriously touchy, so yeah, check that first. Since you're getting fuel out the stack(I assume diesel) it's likely you have everything bled out good. If you open the throttle a bit while running on gas then crack the bleeders on the injectors you get good fuel, right? Must be not sealing the cylinders when you switch over from gas. When you pull your valve cover, make sure that when it's on the diesel side there's clearance between the starting valves and the cam that operates them. Also make sure none of the starting valves are hung open. Might not hurt to double check valve clearance on all the valves while you have it off. A quick check to see if anything basic's wrong would be to pull the coil wire and crank it over in the gas mode. Then, while cranking, switch it to diesel. The extra compression should slow down the cranking speed by quite a bit.
Home
| Forums
Today's Featured Article -
A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
