Re: 706 hydralics
Posted by the tractor vet on March 28, 2006 at 17:33:48 from (66.202.111.193):
In Reply to: Re: 706 hydralics posted by butchmo on March 28, 2006 at 17:23:54:
Well if the spool is that bad guess there is no hope for it so guess you will have to find a good used outside valve and as far as putting in a third valve just no room but if you an find the rear line kit then you can stack those lines on top of the lines going to the ft. outlets and have duals on the back along with the ones on the ft. now if you want three outlets on the rear then ya need to get one of those splite outlets that have the electric spliter . Finding a good valve should not be to hard to do . and all you will need is some O/Rings. as for the second rear remote you will need the correct lines and fittings and longer fitting bolts. they are out there ya just have to go shopping.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
