400 ignition timing
Posted by SDE on March 31, 2006 at 03:30:32 from (69.179.7.82):
This tractor came with a cornpicker on it. (ran seasonally?)It also had numerous igition parts in the tool box,coils,points, condenser. The battery was stamped 97, which makes me believe that 97 was the last time he tried to get it to run. Insanity is doing the same thing, but expecting a different result, so I removed each plug wire and moved them to the next terminal on the dis. cap. It STARTED, but ran like a green machine. Changing the timing did not have any effect. I intentd to put #1 to TDC and adjust the valves and look to see where the rotor points to. It finally occurred to me that maybe they had removed the hydraulic pump for a repair and it wasn't installed properly. Before I remove the freshly filled hyraulic fluid and remove this pump I wanted to know if I am overlooking a different solution to this problem. Thank you SDE
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
