Re: brake bands on H
Posted by Wayne Swenson on April 10, 2006 at 20:20:51 from (24.181.155.110):
In Reply to: brake bands on H posted by lekander883 on April 10, 2006 at 19:50:13:
Left & right are identical. No springs, etc. inside to surprise you. The left side is no different than the right in removal. The PTO is in the rear of the tractor; were you thinking of the clutch pedal? Please replace any leaking seal; the new brake band (& about $40) will be ruined very soon if you don"t. It is not easy to remove the old seal but patience will help. Do not try to remove the cast iron seal retainer; it will break unless gears are removed first. Be sure to get all the old seal removed; it is about 3/4" thick & has an outer liner holding everything together. Replace with 2 (two) new style seals and put some chassis grease in between them for long term lubrication protection. Use steel wool to clean the brake drum sealing surface making sure all scratches are removed before installing the drum on the bull pinion shaft. Lube the brake shoe pivot bushing in the transmission housing and in the brake cover before you slide the new linings in place. Place a small amount of grease in the hole where the brake pivot goes into the transmission housing and be sure the brake pivot works freely in the cover. Oil the area well and let the excess drip off before installing the new bands. After installing the band & getting the pedal free-play to about 1", apply the brake firmly, lock it in place and adjust the setscrew on the bottom side of the cover. (helps to loosen any adjustable parts BEFORE re-assembly) Loosen the jam nut, turn the set screw in until it touches the brake band, back out 1/2 turn & lock the jam nut. This helps prevent the brake from dragging, premature wear, and overheating. Repeat for the other side and adjust the pedals for equal braking effort so when the pedals are locked together the tractor stops without pulling to one side.
Home
| Forums
Today's Featured Article -
Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
