1066 Left outer Tie-rod replacement
Posted by Michael Sheik on April 13, 2006 at 08:56:34 from (199.153.205.246):
When i bought this tractor I knew this was bad. I have been holding my breath hoping it didn't fall off while I was using tractor. I am done with field work for a few days and have the new tierod end from IH (the long one without threads and only slotted holes for clamp and bolt as it is adj. front axle).
The previous owner knew it was bad too as there are pipe wrench marks on the outer tube where it looks like he tried to pull apart and failed. I am afraid that when I try to free tierod end from tube that it is going to be "major" seized up. i am thinking I will probably have to apply heat to the tube and twist and pull to separate. Anyboby else had this problem and have a different method than what I am describing.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
