Re: B valve adjustment, what happened?
Posted by KEB on April 13, 2006 at 17:47:22 from (207.94.26.3):
In Reply to: B valve adjustment, what happened? posted by TKN on April 13, 2006 at 11:48:20:
Hi. Setting the valves to .014 rather than 0.17 would not keep the engine from starting. It may not run as well as it could, and the valves are a lot more likely to burn, but unless there's something else wrong it will run. Assuming you didn't change anything except the valves, you have the classic symptoms of setting the valve lash at TDC on the exhaust stroke instead of the compression stroke. This will result in the valves being so loose they never open far enough to let the engine run. Another possibility is that the valve timing is off one tooth. I've seen car engines run with the valve timing off by a tooth; they have no power & trouble reaching higher RPM. Don't take this the wrong way, but are you absolutely certain you had #1 set at TDC on the compression stroke and not the exhaust stroke? Were the valves really tight & you had to loosen them a long ways to get enough clearance? Quick way to check valve timing. With the valve cover off, watch the two valves on #1 as you turn the engine. The transition from exhaust to intake occurs at top dead center on the exhaust stroke. As the engine turns, you'll be able to see the exhaust valve close at the same time the intake valve opens, almost like the valves are "rocking" from one to the other. This point should correspond to top dead center on the exhaust stroke, and the timing mark should be aligned to TDC, assuming the valve timing is set correctly. One full revolution of the engine past this point, with the timing marks aligned again, will correspond to TDC on the compression stroke, which is the position at which you want to set the valve lash. Good luck, Keith
Home
| Forums
Today's Featured Article -
A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
