SMTA battery drain
Posted by Hayfarmer on April 19, 2006 at 21:16:49 from (66.243.239.190):
My SMTA has been converted over to 12 volts with a Delco S10 alternator, standard 3 wire. I wired the system according to Bob M"s diagram and it works well, but I get a small amount of battery drain over time. The drain seems to be through the Battery wire to the alternator. I think the drain is very slight but over time will drain my battery so the tractor won"t start. What is the best solution? Would you recommend a battery disconnect switch or a switch in the power wire to the amp meter that supplies over all power?
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
