Re: VOLTAGE REGULATOR
Posted by Janicholson on April 21, 2006 at 06:07:48 from (199.17.6.175):
In Reply to: VOLTAGE REGULATOR posted by BOBM25 on April 21, 2006 at 04:41:54:
That terminal is the key to repairing the regulator. There will be a spring (on the back of the coil tower where it is located) that needs to be made to pull upwards on the contact more than it does now. (just like what you do with the screwdriver.) Sometimes there is a bent tab of metal to bend, and sometimes there is a screw adjuster to lengthen the spring. Charge the battery fully with a charger. Open the regulator cover, and start the tractor. Use the - voltmeter lead on the battery terminal of the regulator , and the + lead on the meter to good ground. Adjust the voltage to 6.8 to 7.1 volts. this will charge the battery well, but not overcharge. Replace the VR lid and check the voltage again, the lid affects the magnetism in the regulator and can cause under, or overcharging. If still in spec, button things up. If not adjust the cover off voltage so that the cover on voltage is good. The Amp gauge may not show high charge (because the battery is full) but if the volts are correct it will do the trick. Good luck (old auto repair books are a great source of info) JimN
Home
| Forums
Today's Featured Article -
Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
