Re: h smokes
Posted by Janicholson on April 22, 2006 at 18:29:21 from (66.173.50.129):
In Reply to: h smokes posted by donald schnupper on April 22, 2006 at 16:55:50:
Yes, If the guides are less than .002 measured lateral movement on the stem, I would put Perfect circle seals on it (with air pressure to the cylinder when it is at TDC, and held there so the valves cannot drop into the cylinder) the spring can be removed and seals installed without head removal.
A spell of ideling, (or down hill in high with the throttle closed) will pull in oil. Then when the throttle is opened, it will smoke like a green wood fire. If it smokes under load for as long as it is loaded I would re ring it, (or a piston/sleeve kit)
JimN
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
