Posted by redrider on April 09, 2009 at 19:39:58 from (66.235.45.149):
In Reply to: 53 SH disc brakes posted by Deano4863 on April 09, 2009 at 19:12:07:
This is the method I used when I reconditioned the disc brakes on my 300F. To make these brakes like new you have 4 different surfaces to turn. The outer housing, the two actuaters and the bull pinion bearing retainer. The total amount removed on these 4 surfaces needs to be removed from mating surface of the brake housing. If this is the first time anything has been turned then usually you can measure the indentation wear surfaces to get a rough idea how much wear deteration there is. You almost have to reassemble the brakes and check the amount of travel in the actuaters. When you have the brakes adjust up (not to tight) you want the two actuating links that attach to the operating rod yoke to be as straight as possible this will give you more leverage when actuating the brake. I hope I have not totally confused you.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
