Re: Farmall M what next
Posted by Janicholson on May 09, 2006 at 13:05:07 from (199.17.6.175):
In Reply to: Farmall M what next posted by sccwells on May 08, 2006 at 20:28:42:
The corrosion of the aluminum piston can expand so much that it puts drastic pressure on the cylinder wall, locking the sleeve in the cast bore beyond its press fit. I would buy or borrow, or make up, a fly cutter (machinist term for a one cutter hole cutter with a short blank center locater that goes in a drilled hole in the center of the piston). It would be 1/8" smaller than the bore diameter. I would machine away the top ring land (and remove the top of the piston). Once the top is removed, there will be no center hole to use, but a saws all should be able to cut out to the back of and through the remaining compression piston rings, cast iron is easy to cut. (be careful to stay parallel with the cylinder). Once the tension is off the circumference of the piston, it will move. Just my way of doing the deed. JimN
Home
| Forums
Today's Featured Article -
Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
