Re: B-414 brakes
Posted by FromJB2 on May 13, 2006 at 07:09:26 from (72.56.121.128):
In Reply to: B-414 brakes posted by wkw on May 10, 2006 at 07:51:05:
Hi Ken, the brakes on the B414 are disk brakes. They are located inside an enclosure on each side of the transmission case by the back of the running board. Inside each enclosure is an inner and outer disk rotor with a friction lining on it. In between the disk rotors is a ramp and roller mechanism that when you step on the brake the rollers in between 2 metal disks roll up a ramp and expand the distance between the metal disk and jamb them against the disk rotors. Common problems: 1)Ramp and roller mechanism gets clogged with brake dust. 2)The brake lining on the rotors becomes glazed reducing the friction. Repair is to remove the braking mechanism from each side of the transmission housing, clean the ramp and roller mechanism, apply very little powdered graphite grease to the ramp and rollers. Next remove the glaze from the disk rotors by using a wire brush or some other tool to roughen the surface. Now sometimes the rotors have been replaced and the brakes are worse because the new rotors do not fit inside the groove worn on the braking surfaces and only make contact on the outer edges. Solution is to grind away the outer edge of the rotors. Some people don't like this solution and would have the braking surfaces turned but that is costly and causes other problems. Good luck JB2
Home
| Forums
Today's Featured Article -
Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
