Re: 450 gas starved
Posted by RustyFarmall on May 14, 2006 at 06:13:13 from (207.32.13.217):
In Reply to: 450 gas starved posted by red barn hay on May 14, 2006 at 05:41:27:
Try it with the gas cap removed first, if that works, you need a new cap. The next thing would be to shut off the fuel under the tank and then remove and clean the glass sediment bowl, there is also a fine mesh nylon screen that sits on top of the glass bowl, make sure it is clean also. You could also have a bunch of crud and rust in the fuel tank, which is restricting the flow, and the fuel inlet fitting on the carburetor also has a fine mesh brass screen attached to it. This screen may also be plugged. The last thing to check would be the needle valve and seat inside of the carburetor, the carburetor will need to be removed and disassembled to do this. If you trouble shoot in the order I have suggested, you will avoid any unnecessary work or expense. Here's a hint, the sediment bowl may not want to come apart, and it may leak when you put it back together. A brand new sediment bowl assembly is available for about $20 to $25, not much point in trying to repair the old one.
Home
| Forums
Today's Featured Article -
Fasteners: The Nuts and Bolts of Nuts and Bolts - by Curtis Von Fange. The nuts and bolts of nuts and bolts is an interesting and essential piece of knowledge that applies to our older tractors. An improperly torqued capscrew on an engine head or a shear bolt that is too hard on the driving shaft of a bushog can create havoc and make an expensive and uncalled for repair. Let’s examine the purpose and design of these fasteners in order to ensure their proper use. Fasteners are probably one of the aspects of mechanics that is given the least amount of thought.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
