Farmall H 6 Volt Voltage Regulator - Resistor on F
Posted by Ed McCullough on May 21, 2006 at 12:19:10 from (71.162.33.196):
With the help of John Nordhoff's excellent Non Charging Troubleshooting Procedure obtained in a posting in this forum, I have isolated the non-charging issue (I think) with my 1949 Farmall H to a failed resistor which is in series with the field terminal on the 6 volt 4 wire voltage regulator. When I grounded directly from the field terminal on the generator to the tractor frame, and after polarizing with engine running by briefly jumpering from Armature post on generator to BAT terminal on regulator, a small spark was seen and charging rate of ~10 amps was indicated. Removing the direct ground results in complete loss of indicated charge. A charging state cannot be obtained by directly grounding the regulator saddle bracket to the tractor frame. The resistor believed to be the problem is marked "1 ohm - NEXCOR - 9650", but a check across the resistor with a multimeter indicates an open circuit rather than a small resistance. My conclusion is that the generator is OK, but the regulator (specifically the resistor) is the culprit. My question: What are the potential negative impacts of simply removing the 1 ohm resistor and attaching the wire directly from the generator field terminal to the "F" lug on the regulator (without the 1 ohm resistor in between.) As can be seen by examining the rightmost terminal in the attached photo, this would result in a direct path to ground from the generator field post. Alternately, if the resistor is necessary, where might one look to find a replacement? If available, it will certainly be more cost effective to replace the resistor than the entire regulator, but it is often difficult to come by small replacement parts such as this. Another issue I am dealing with is that all that is available locally is a 3 wire regulator. I am replacing a 4 wire unit, and I would prefer to avoid a rewiring exercise to run lights from the ammeter output rather than the "L" terminal on the regulator. Thanks!
Home
| Forums
Today's Featured Article -
Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
