Re: ELETRIC SYSTEM ON FARMALL M
Posted by El Toro on May 24, 2006 at 18:21:33 from (152.163.100.65):
In Reply to: ELETRIC SYSTEM ON FARMALL M posted by JIMMYJAYJOHNSON on May 24, 2006 at 16:22:55:
If this tractor has battery ignition, have you checked for battery voltage at the coil? If you are using (+ plus) ground on the battery, the plus terminal wire on your coil goes to the distributor. Use a volt meter or lite to check for voltage at the coil with ignition switch on. If you have voltage at the coil, pull the coil from the cap and hold within 1/8-1/4" of a good ground on the tractor while someone attempts to start tractor. You need to check the point gap, should be .020". Clean the points with some 320 grit and then clean them with a cotton swab dipped in alcohol. You should have a hot spark from that coil wire. Hal
Home
| Forums
Today's Featured Article -
Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
