Re: Used tires 13-38
Posted by Nat 2 on June 02, 2006 at 20:25:03 from (24.93.8.168):
In Reply to: Used tires 13-38 posted by SDE on June 02, 2006 at 14:43:22:
Mismatched tires do detract from the aesthetic and monetary value of a tractor, but there is a hidden danger of having two mismatched tires that aren"t the same diameter.
See, just because two different brands of tire say 13.6x38, for example, doesn"t mean that they"re the same diameter. Off by an inch in diameter means off by about 3-1/8 inches in circumference. With the tractor going in a straight line, one wheel will turn a little less than the other. For each revolution of the smaller wheel, the bigger wheel will only turn about 98-99% of the way around. This in turn will cause the spider gears in the differential to turn ALL THE TIME, when they"re only meant to turn while the tractor is going around a corner or one wheel is slipping. This causes undue wear on the differential, and could cause premature failure.
It"s really far more pronounced in cars where the transmission works are turning much faster, but in 30-40 years, you might see a problem on a tractor... Before you say, "Ah, it"s no big deal," remember that we"re talking about tractors that are 30, 40, or more years old! A-ha!
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
