Re: Transmission question
Posted by Dave Slater on June 08, 2006 at 14:52:37 from (64.12.116.65):
In Reply to: Transmission question posted by newpuller on June 08, 2006 at 10:25:38:
Sounds like you have top off transmission already. If so drain oil remove PTO,belley pump and split tractor or remove drive shaft from clutch to trans underneath through pump hole.Remove input shaft housing with input shaft.Unbolt the 3 bolts that hold main or pinion shaft in,slide forward and remove keeping the shims to go back if using the same pinion.Remove brake return springs and linkage,remove brake spring return lever left side and clutch pedal.Remove any burs on shaft.slide brake pedals and shaft to right until the end is past counter shaft rear bearing.remove retaining ring from counter shaft at rear of bearing.The bearing needs to slide out of housing and off shaft to rear.Remove belley pump drive lug from front of shaft.Tip its best to loosen this nut before removing top trans shaft.lock in 2 gears to keep it from turning.drive lug is right hand threads.Next remove front retainer with seal,counter shaft slides to rear out of front bearing.Now if you hold your mouth right you can lift shaft out top with gears on it.Kind of long hope I didn't miss anything and good luck.
Home
| Forums
Today's Featured Article -
An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
