1066 PTO Pressure Check/Adjustment
Posted by Michael Sheik on June 15, 2006 at 06:46:17 from (199.153.205.246):
I am needing to check pressures on the PTO on my 1066. I recently replaced the rubber boot on top of control valve stem and did not realize when doing so that I could affect adjustment by moving valve adjustment nut and most likely did. Does it take a special fitting to screw in where the plug is to check pressures and set? I have manual and it spells out procedure but does not mention any special plug.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
