Re: wd6 carb air-fuel mixture
Posted by KEB on June 22, 2006 at 20:42:16 from (207.94.27.6):
In Reply to: wd6 carb air-fuel mixture posted by tyler cohrs on June 22, 2006 at 19:07:32:
Three things to start with. First, make sure the float level isn't set too low, which will result in not enough gas in the bowl. Also, check the compression release linkage & the cam in the carburetor. If the cam in the fuel bowl isn't adjusted right, it'll hold the needle valve partly closed, resulting in a lack of fuel. Second, just soaking doesn't necessarily clean out all the passages. You need to make sure that you can blow air through all the passages. Aerosol carburetor cleaner is good for checking that passages are clear. Third, make sure you don't have a vacuum leak in the manifold or where the carburetor connects to the mainfold. A vacuum leak after the carburetor will require that the mixture coming out of the carburetor be excessively rick to compensate for the extra air. Drilling the jet would be the last thing I'd do, and I'd make sure I could get a replacement before I touched the original one. These are an oddball carburetor, and I've never tried to buy parts for mine. By the way, my WD-6 requires choke to fire, but then runs fine without choke once its turning over. Keith
Home
| Forums
Today's Featured Article -
Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
