Re: H Problems
Posted by KEB on June 23, 2006 at 20:35:21 from (207.94.27.7):
In Reply to: H Problems posted by IndianaRed on June 23, 2006 at 10:03:36:
While you're at it, have the rod ends checked for size & out of round & look carefully at the main bearings also. Cam bearings might also be suspect. If you've got the engine that far apart, you might as well pull the cam and have the machine shop take a good look at it, too. Bearings spin from a lack of lubrication which causes the bearing shell to seize to the crank. I've seen a couple instances where the bearing seized hard enough to the crank to spin the shell in the rod end - one was an old air cooled VW engine that had been run out of oil. If it seized that tight, good chance the crank is toast, as it'll probably be gouged too deep to be turned. Remember the science experiment in grade school where you sprinkled iron powder on a sheet of paper with a magnet underneath, to see the pattern of the magentic field. Magnaflux is just a more sophisticated version. The magnetic field will separate around discontinuities in the metal, such as a crack, which will show up as a distortion in the pattern of the test media. Finds cracks too small to see or feel. Depending on what your goal for the tractor is, you might scrounge around & find a parts tractor with a useable crank & rods. If you're really lucky, you might find one that has usable pistons & sleeves as well. Paying for the machining, new rings & bearings, & a gasket set is a lot cheaper than all new parts. Good luck - I hate it when things like that happen. Keith
Home
| Forums
Today's Featured Article -
A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
