Re: timing a 436 motor
Posted by Sheepdog in NE on June 25, 2006 at 19:55:44 from (67.0.14.107):
In Reply to: timing a 436 motor posted by Larry B. - 1466 on June 25, 2006 at 17:49:59:
There is a cover that the tach cable goes to opposite the fuel pump. Take it off and you'll see a gear with 3 bolts holding it on. Loosen the bolts. Also take out a plug using a 1/2" drive ext, that is located a about 7 o'clock under the pump mounting flange. Make sure the flywheel is on your #18 setting. Look in the plug hole and there will be two marks. They need to be lined up with each other. Take a socket (maybe a 3/4 or 15/16) place it inside the three bolts you loosed and you will move one of the marks. If it is not moving then you are at the end of the slots with the 3 bolts and you need to remove the 3 bolts pull the gear off and move it one tooth. Then you'll be able to line up the marks. Tighten the three bolts. Not sure on the torque setting thou.
Home
| Forums
Today's Featured Article -
Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
