Re: 1950 M ignition starting problem
Posted by John T on June 26, 2006 at 14:55:19 from (66.244.90.5):
In Reply to: Re: 1950 M ignition starting problem posted by jpl on June 26, 2006 at 09:45:06:
jpl n Rusty, If he happens to have one of those solenoids with the extra lil (I) terminal (like Ford n some GM used) its hot with full battery voltage ONLY when the solenoid is engaged (its cranking) and thats good for and used when one uses a 6 volt coil with an "External" Ballast Resistor on a 12 volt tractor. What it does is effectively by pass the ballast and apply full unballasted battery voltage to the coil (ie. 12 volts on a 6 volt coil) ONLY while cranking. Thats what some farmers call a "start on 12 and run on 6 coil system"........HOWEVER if theres no external ballast to by pass, the solenoids lil extra lil I terminal (or any other terminal for that matter) dosent apply any more voltage to the coil (assuming switch n all else is okay) then what normally comes from the regular ignition switch feed. HOWEVER if the switch contacts (resistive/carboned/loose) or the switch wiring is bad, the extra lil jumper wire to the coil could help and it cant hurt nuttin so its worth a try BUTTTT its not the normal or factor way, it is the factory way when they use a 6 volt coil on a 12 volt tractor with an external ballast and want to improve the starting spark energy and yessssss it works great. Bottom line is its NOT ordinary but it cant hurt and might actually help as a band aid approach (but he needs to fix the REAL problem) if the switch or wiring has some resistance and is dropping voltage. Fun chat, yall take care n God Bless John T
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
