Re: 400 throtle ajustment
Posted by JANICHOLSON on June 27, 2006 at 21:00:36 from (134.84.102.134):
In Reply to: 400 throtle ajustment posted by budaa on June 27, 2006 at 11:14:58:
Budaa, It is quite common for the linkage to act like that. The issue is whether it is wide open, when in the last notch. (do this with tractor off) Look at the governor control lever on back of gov box. With the hand lever at idle, the gov. lever will be relaxed. Then look at it with it at full throtle on the hand lever. It should move substantially. With the hand lever in that position, disconnect the link to the gov arm. Pull the gov arm farther in that direction against its spring. If the lever will not move farther, the adjustment is OK. if it does move farther than the rod pushes it, the rod needs to be made longer (adjustments in threads) so that it is moved all the way to its stop. The wide open condition is regulated in the governor, not the link, so do not worry about overspeeding the engine by this adjustment. (not all farmalls have the same setup, some have external links to the carb, these can cause serious overspeeding if wrong. Good luck, JimN
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
