Re: Hey Gene
Posted by Gene-AL on April 10, 2009 at 10:44:21 from (68.212.195.166):
In Reply to: Hey Gene posted by Montana Dan on April 09, 2009 at 18:03:13:
Dan,
I've based everything I've written on your report of positive +10V at the Arm terminal with Arm wire disconnected and engine running.
If the voltage output from that Gen Arm is truly positive (with Arm wire disconnected) despite your re-polarization efforts, then there's something about that generator/VR that's different from what is expected or something has been missed.
Permanent magnetism in the Gen field poles could prevent a polarization reversal, but I don't know if that happens.
JimN is correct in saying that the cutout relay is probably not opening its contacts. What else but the Gen Arm would draw so much current, but stop after a batt disconnect and then re-connect?
JimN's suggestion to use a diode will work IF the Gen output is negative and Batt is also negative (diode cathode side connected to Gen Arm). But if the gen output IS positive and the Batt negative, the diode will never turn on to connect Gen to Batt as the coutout relay evidently does.
I'd bite that battery box 'bullet' and swap the battery to negative ground (temporarily?). At least, you'd know if you have a charging system that works (Ammeter will indicate backwards if it works, unless you swap the leads).
Troubleshooting often leads to hair loss and missteps. BTDT for more years than I'd like to say, but I still have most of my hair...
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
