Re: 1947 Farmall A
Posted by Nat 2 on July 04, 2006 at 05:24:56 from (24.93.8.168):
In Reply to: 1947 Farmall A posted by Bill in VT on July 04, 2006 at 04:20:20:
That's an overflow drain, really. Not picking on you specifically here, but it just baffles me how so few people know even the most basic troubleshooting techniques for a simple 4-stroke gasoline engine... Air, fuel, and fire at the right time. Suck, squeeze, bang, blow... They're not that complicated, yet so many people just stand there and scratch their heads, or check useless stuff like oil, coolant, muffler bearings... Air is generally a gimmee. It takes a lot for the air passage to get plugged, and odds are if the tractor ran fine yesterday, the airway ain't blocked. Timing is also usually a gimmee, if you shut the tractor off because you were done using it. All bets are off if the tractor went "BANG!" and suddenly quit, though. You'd have mentioned that in your post, though, RIGHT? (There have been cases where people have failed to mention OBVIOUS physical damage, i.e. a rod sticking through the side of the crankcase...) Fire is the next thing to check. Magneto or distributor? If you pull the coil wire off at the distributor cap, hold it 3/8" from the frame, and have someone crank the tractor over, does a hot blue spark jump the gap? If not, you have no fire. Fuel is the last thing. Carbs get stuck sitting overnight, and like Hugh said, you may need a carb kit. Then again, the gas draining may be a result of you cranking and cranking and cranking and cranking with the choke pulled. That sucks lots of gas into the intake, and it will run out the overflow. Anyway, if it doesn't fire within the first few cranks, cranking on it more ain't gonna make it start. GET OFF the tractor and start troubleshooting.
Home
| Forums
Today's Featured Article -
A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
