Re: starter switch
Posted by John T on July 05, 2006 at 05:25:00 from (66.244.90.5):
In Reply to: starter switch posted by Carlton on July 04, 2006 at 19:50:15:
Carlton, Lets start with: 1) While a good and fully charged 12 volt battery ought to read around 12.6 volts sitting, it could still have problems which would cause the voltage to drop extremelyyyyyyyyy low (to low to crank the engine) when you apply a heavy load such as a starter. You need to have a battery shop Load Test to really know what shape its in and/or try another known good substitute battery or a jump n see what happens. Insure theres electrolyte above all the plates and that no cells exhibit a gray or milky color indicating a bad cell. 2) Once you know the battery is good and/or you tried a good substitute or a jump n she still dont crank (and you already said the starter n solenoid checked out) the next thing I recommend is you remove, clean n wire brush, then reattach each n every battery n starter n solenoid n ground connection CUZ A BAD OR CORRODED OR LOOSE CABLE OR GROUND OR BATTERY TERMINAL MAY WELL BE THE PROBLEM !!!!!!!!!!!!! 3) You asked about the switch, you can by pass test that by momentarily applying hot battery voltage (like from the battery cable side of the solenoid) using a jumper wire over to the lil S activation terminal on the solenoid which should activate the solenid to pull it in to engage the starter motor. Thats hot wiring or jumping the solenoid in case the starter switch isnt putting voltage to the solenoids lil S activation terminal like it ought to. If hot direct jumping the solenoid makes her crank yet the start switch doesnt, then the sawitch is bad or its wire down to the solenoid is bad. The switch is easily tested by placing a test lamp on its To starter terminal n seeing if its lights up in the start/crank position as it should. Be sure it has voltage to its BAT input terminal and check the wire from it to the solenolids lil S activation terminal cuz if the switch checks good but theres no voltage getting to the solenoid then that wire may be bad/open. 4) It may be possible depending on access and room to manually jumper cable around the solenoid (in case its bad) by jumping hot battery voltage either direct from the battery or where the big battery cable attaches over to the starters big input post (same place as solenoids output post) but thats a high current and arcing connection so take care !!!!!!!!! SUMMARY: Check the battery and/or have it load tested and try a known good substitute,,,,,,,,insure alllllll cables n grounds n battery connections and the starter n solenoid connections are good n tight n not loose or carboned underneath (remove n clean n wire brush allllllll of them especially the Ground) YOU MAY JUST HAVE A BAD GROUND OR LOOSE OR CARBONED CONNECTION,,,,,,,,,,,test the ignition switch n its wiring and try to hot wire the solenoid. Best wishes n God Bless John T
Home
| Forums
Today's Featured Article -
Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
