Re: Transmission noise
Posted by Theman on July 10, 2006 at 07:59:33 from (65.248.77.5):
In Reply to: Transmission noise posted by mc2 on July 08, 2006 at 20:30:49:
I think you have a bearing out. The 1st - reverse gears are at the back end of the countershaft and since you don't hear the noise in low gear, it will be one of the front transmission bearings of which there are 4: 1) The pilot bearing as mentioned in an earlier post, 2&3)The two driver (input) shaft bearings, or 4)The countershaft front bearing. Fortunately, all of these bearings can be changed without removing the top deck or splitting the tractor. Just drop the Liftall pump and remove the drive shaft. Drain the transmission oil next. It will only be necessary to remove the front plug which means you probably won't need more than a 5-gal. bucket. Since it is the easiest to get to, check the countershaft bearing first. Remove the slotted Liftall driver (right-hand thread) and take the oil seal housing off (3 screws). Thread the driver back on the shaft and wiggle and listen to it to see if that is the source of the slop. If you hear the familiar clunk, you've found your problem. This bearing has an external snap ring on the outer race which doesn't need to be removed. Instead, use it to help you work the bearing out. There is a snap ring at the other end of the shaft so you don't have to worry about pulling the shaft out of place. To get to the pilot bearing, which is your next suspect, remove the input driver shaft housing. You don't have to remove the front yoke to do this. Just take out the 6 or so cap screws on the housing and pull it out straight forward. Looking inside the transmission, the pilot bearing is on the end of the shaft. It is a roller-and-cage type bearing. The shaft and the inside of the constant-mesh gear you just removed serve as the bearing races. Inspect all surfaces and make sure all the bearing rollers are there. It is easily removed when you take the bolt out of the end of the shaft. This bearing is uncommon and unless you have a very knowledgeable local source, go to Case/IH. It will help if you don't go on an empty stomach. The other two bearings are in the housing you just took out. Check for excessive slop. This can cause a lot of growling noises - even in neutral since it always drives the countershaft. If you have to take it apart and the yoke is stuck tight, put a spacer or short socket on the end of the shaft and use the long clutch shaft with a couple of 3/8" bolts to "pull" the yoke off. If there is any sign of leakage, replace the seals. Gaskets are available from Case/IH. If they are the 63 year old originals, it is recommended.
Home
| Forums
Today's Featured Article -
Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
